O5Q45 »
https://forums.nicoclub.com/o5q45-u267923.html
Sat Aug 05, 2017 11:30 am
I was wondering where to find more info on this learning transmission in the F50’s. I’m not sure if previous Q’s had adaptive transmissions or not, however the only info I can find is just the fact that is a adaptive transmission.. Since this transmission is used from Xterra, Pathfinder, Titan, and the Q and probably some more Nissan products, is this adaptability something unique to the Q? Does this RE5R05A transmission perform adaptive learning in all forms?
Ultimately my final question is- how many shift pattern maps does this adaptable transmission have to choose from?
Are there multiple economy patterns and multiple aggressive patterns? My guess is there are probably just 2-
Lastly- how are these patterns monitored and at what point will the adaptive portion determine if a new pattern is necessary?
Will a simple battery disconnect (over-night?) prompt the transmission to choose a new pattern?
I would like to know what the default map (shift pattern) would feel like. I wish I could decide if I wanted it to do this. I’m afraid to find out that this may be a bs sales tactic since I can’t find difference between the say, Xterras transmission and mine- they both are RE5R05A.
This adaptability would be in the programmed shift points for each vehicle based on what motor it is attached to and vehicle weight I assume.
Has anyone here ever looked into the program and saw any coding for adaptive learning?
