Pornflakes »
https://forums.nicoclub.com/pornflakes-u4333.html
Sat Oct 11, 2003 7:04 am
For the Cobra MAF, all you need is the MAF connector (available at ford) to hook it up to the MAF harness in the engine bay.
If you can't find the wiring diagram, just tap into the wires with a digital voltmeter when the vehicle (or the ignition key) is on. One of the wires is 12V (feeds power to the MAF), one is ground, and the other is the MAF signal that goes to the ECU. All you need to do with the voltmeter is find the 12V and ground. The third wire is the MAF signal. Sometimes you will have a fourth wire (of the same color as the ground wire). This is just another ground.
