smockers83 »
https://forums.nicoclub.com/smockers83-u49766.html
Sat Mar 24, 2007 8:25 am
wash the car, then use a light automotive abrasive like Meguiar's Body Scrub or Mothers Pre-Wax Cleaner on those spots. the clay bar will work if its a surface defect (hard water deposits) but if it looks like its etched in (anything acidic--acid rain, bird poo, sap, bugs), your best bet is to use the abrasives--do not use pressure, let the product do the work for you. if its etched in you might start taking off clear coat and get down to the paint using the clay bar or using to much pressure with the abrasives. once you've done this, you can go to waxing and polishing.
hope you don't have to go to the paint shop
