BrandonR. »
https://forums.nicoclub.com/brandonr-u156313.html
Mon Mar 15, 2010 4:53 am
Ok, I own a '95 Q45 with about 188K miles on her. Mostly everything still works just fine, except for the old Bose system and the Driver side window.
Though now I am encountering a few problems......
1. The power steering is loud again. I say "again" because it used to be loud until I replaced the alternator and battery. Then it was quiet again and steered a little smoother, until the battery went dead ONCE (left interior light on overnight) and then it was back to being loud. It works, but you can hear it working. I'm guessing it's not getting enough power or something.
2.Acceleration, seems to be a big problem in these cars. It's funny, sometimes it takes off like a bat-outta-he** , and other times it feels like half my HP is gone and it takes it's sweet time getting to the next gear. Sometimes it does this and then all of a sudden it takes off with normal power around 2500-3000RPM's. Sometimes higher. Usually this happens from a stop, and it doesn't happen all the time either, probably about 30% of the time. Sometimes while this is happening there is a little bucking like it wants to go but can't. There is no knocking or pinging.
I've checked all my vacuum hoses, fuses, and wires. It seems to me like both these problems are due to low Voltages or something, i'm not a mechanic but I have a firm grasp on what's going on usually with my car. The engine sounds great, still has a lot of power besides lagging a little between 80-90mph(2600-3000RPM in 4th). The TCS seems to have nothing to do with these problems, does it with it on or off. The transmission doesn't seem to be slipping or failing. When problem #2 isn't happening it has no problems accelerating AT ALL. It's still pretty fast for all the miles. Oh, not burning or leaking and fluids eithers. I have not tried cleaning the MAF yet, looks clean.
Oh, btw, am I supposed to have a 25amp fuse in the "Injector" slot in the main fuse box under the hood? One of the brown sqaure ones. I don't, but the car still runs. Not sure about that one......
Thanks ahead of time to anyone willing to read all of this!
