Retro Fitting AC to 1988 Truck
anthony1988
Car: 1988 Nissan Pickup
Standard Trim 4-Speed
Z24i
do you know if Nissan dealers today can still retrofit options on the old Hardbody trucks? Like for example my 1988 Nissan Pickup 2WD has No Air Conditioning in it and can dealers install to this day?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Parts for these trucks are being obsoleted and removed from inventory at an alarming rate. The dealer can do anything you ask so long as the pdc's still have the parts available. Once a particular part is sold out the chances of Nissan restocking the part is closer to 0%. If you want to add AC I'd consider raiding a junk yard truck for any good parts you can find. I'll be removing the AC from my green truck this year if you wanna make an offer on those parts.
anthony1988
Z24i
Rev what year is your green truck? my truck is an 1988 year model and the A/C system may be a R12 System I see in your bio you have a 1995 year model? or is it the 1991 Model? if its the 1995 year model chances it may not work because its R134a system
Rev_D21
Correct, the 1988 trucks came with R12 but that was banned from use and most manufacturers had switched to R134A by 1995. You will need to install a R134a system or retrofit a r12 system to R134a. While not everything will transfer from my truck to yours a lot of it will and you will be ahead of the game since it's already R134A.
Q451990
:gapteeth:
anthony1988
Z24i
But is the set up same for all the hardbodys? So when I do install a R134A system, do I have to change anything (such as wiring etc?) for the R134A System to work?
anthony1988
Z24i
Rev_D21 wrote:Correct, the 1988 trucks came with R12 but that was banned from use and most manufacturers had switched to R134A by 1995. You will need to install a R134a system or retrofit a r12 system to R134a. While not everything will transfer from my truck to yours a lot of it will and you will be ahead of the game since it's already R134A.
But is the set up same for all the hardbodys? So when I do install a R134A system, do I have to change anything (such as wiring etc?) for the R134A System to work? Like I probably need to find a Later hardbody (1995-1997?)
