Ac Fan
midnightsliding
I was wondering since i dont have A/C in my 240, could i take the belt driven fan out, and wire the AC fan up to turn on and keep the car cool, or would the A/C fan not be enough to keep the water temp. down?thanks
MikeMurphy
Car: Guess
From what I have heard, the AC fan is enough air to keep the KA from overheating in reasonably hot weather. Second hand knowledge but I hope it helps.
midnightsliding
ok, thanks alot
midnightsliding
maybe i can find another one liying around and wire two of htem up to be on the safe side or something, or do u think i should just keep one?
Exar-Kun
Car: 2005 350Z
just get a nice electric fan and get rid of your entire A/C system and all :)thats what Im doing.-chet
midnightsliding
yeah well right now i dont have a motor in the car, but i have removed all the a/c lines and compressor, and condincer, and i was tring to go the cheap way out, by using the A/C fan, and i have two A/C fans at my house i was just wondering if that would be enough and MikeMuephy said that one would keep the water temp. from overheating. so i mean i got two fans and i would rather save 130 dollars for something eles right now, like a new motor.but do u think that two would do the trick for now, and maybe once i get everything running right I will invest in a good set of fans. thanks
574-240sx
Car: Nissans, Toyotas, Subaru
It works fine thats what I have setup on my car now. Once I start my car I have the relay hooked up to the fan. I still watch my temp. It works fine. I only had temp rise a few times but i turned on my heat and it went down, that was sitting in traffic for 30 minutes plus on a 90 degree day. Just don't drive in heavy traffic and you will be fine. Nick
midnightsliding
alright thanks, we dont have that much traffic around here anywaysthanks
