Hey all, every once and awhile my ABS light decides to turn on. Restarting car gets rid of the light. Should this ABS light be turning on if the ABS decides to activate? or will the light occur only if there is something wrong with the system? I've noticed the issue more ever since I replaced the brake master cylinder (bled the brake lines etc). Brake feels fine, but everyone once and awhile I hear the ABS motor running for a few seconds... sometimes it runs longer and causes ABS light to come on. I forget where, but I remember hearing that some brake lines around the ABS need to be bled.. not sure if this would cause my issue.
Thanks.
