teddy »
https://forums.nicoclub.com/teddy-u22985.html
Thu Nov 24, 2005 6:32 pm
1. I don't know
2. I suppose you could do either way, whichever you prefer. I had my harness off when I dropped the engine in. Then after I had the harness serviced, I put it on with the motor in the car. I suppose this might be a little more difficult than with the motor out, but it wasn't a big deal.
3. A few people on here have bought the XS power i/c kit on ebay. It says it's for a CA, but the general consensus is that the piping needs a little modification on the cold side to work. The s14 coldpipe is what you would need for the CA, although I dont have any personal experience with that. The XS kit usually runs for about 300-400 I think, give or take a few. S13 hotpipe works with the stock/s13sr t25. A t28 will require some modification.
4. The stock ka radiator will work fine, especially if its 30 degrees out. But an upgraded radiator is always a good investment.
Hopefully other people can answer what I havent or add more.
