A Few Fluid Questions
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
Alright guys I just swapped in my CA18DET and I have 2 questions for putting fluids back in.
1.) What fluid brand and viscosity should I be running in your ca18 transmission?2.) Also what clutch fluid brand and viscosity should I be running?
Any answers, opinions, and tips would be greatly appreciated. Thanks.
-Alex
F3600
all these question can be found in the ca18det manual (easy to find on the net).
I dont remember the oil for the transmission but just use regular brake fluid for the clutch system. I think it need to be dot3 brake fluid ..maybe someone can help more on that
Good luck
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I've always used the BG Syncroshift from the GM dealer. Stuff is great! As for clutch fluid? I just use some DOT3 brake fluid....
teddy
Car: Saab Turbo and MR2
use a gl-4 transmission fluid, I use pennzoil synchromesh. It's identical to the GM stuff, but you can buy it at Autozone or wherever for like 4 bucks a bottle. For clutch fluid, just any dot3 brake fluid will work. I use the prestone stuff because it's cheap and effective.
float_6969
I'm using Redline MT-90 in my transmission. What ever you do, DON'T USE A GL-5 FLUID. IT WILL DESTROY YOUR SYNCROS!!!. As for break fluid, I'm running redline Dot 5.
