A/C Help!
nismospec19
Car: 90 s13 Hatch SOHC JDMness
I am trying to fix the A/C in my girlfriend's truck. There is a crack in the metal end of the low pressure line. The issue is that I am unsure the name of this piece or if if it can be replaced without replacing the whole line
Piece Highlighted in Yellow
Modified by nismospec19 at 5:20 PM 4/21/2009
RT
Car: 1991 nissan king cab pick up
if the line has a crack the entire line needs to be replaced. cost more to fix a line than buy one. Go to junkyard and find one.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Low Pressure line from Compressor to firewall. Can possibly be repaired by a radiator/hose repair shop by will likely need to be replaced along with the o-rings inside the line. Don't use standard Buna o-rings, use AC o-rings designed for the job.
InsertNameHere
Car: 92 Hardbody
Mine cracked too. Right where the line meets the flange on the compressor end. I've been looking for a new low AC line for months. I hardly ever find hardbodies in the junkyards by me. Good luck finding one.
YEPEE
Car: 02,Spec-V, 87.D21
have you checked online or at a stealership?what year is the truck?
InsertNameHere
Car: 92 Hardbody
I've seen the low line online for ~$75. The stealership by me has an insane markup on parts. I'd much rather spend that $75+ on other areas. The heat isn't too bad since I'm near the beach, but it would be nice to have AC.
nismospec19
I have checked around, dealership prices are ridiculous and online is hard to find through second hand parts strores
I am wondering if the line is similar to a singe cams in a 240?
RT
Go to a shop that does industrial hose making, they can make any pressure line cheaper than any dealership. Look in yellow pages under industrial hose or materials.they can make lines to fit anything and usually cheaper than a dealer hose.MUCH cheaper, just take old line to them they can make it.
InsertNameHere
Car: 92 Hardbody
I looked at a few 240s in the junkyard and they looked different.
jimbo13njax
i got one laying around, let me see if i can find it
