ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Sun May 27, 2007 2:22 pm
The clutch and A/C works when I jump terminals 3 and 5 at the relay with a wire. I've replaced the relay with the cruise control relay and no change. The low pressure switch is closed (I believe that's as it should be). About all I haven't done is had the refrigerant evac'd and weighed to make sure there's plenty in there. Is 95-100psi (on both high and low sides) at 70* air temp about right when the system is at rest (no compressor clutch going)? Shouldn't it at least try to kick on? When I jump the wires to make the compressor come on, it works well. As it's running the high pressure line gets hot and the cold line gets cold. I also can't see anything in the sight glass (no bubbles, no foam).
I took the case apart for the auto amplifier and saw nothing out of the ordinary. Of my two other Q's, neither has working a/c so I don't know that the amps in those are good.
