richardvestal »
https://forums.nicoclub.com/richardvestal-u69729.html
Mon Jul 02, 2007 6:56 am
1999 Q45t with 120,000 miles.
Bought it used w/ extended warranty. Never had much trouble, except left headlight and the air conditioning temperature dial wanted to go in reverse. Thankfully, both were changed under extended warranty.
Just recently the "service engine soon" light came on. Autozone says it is both knock sensors and the EGR valve. I bought both KS before finding this website.
I am planning on doing this job myself. Just finished replacing the plenum gaskets on my sons 96 firebird and I feel up to it!
All the posts on this forum talk about changing the hoses and wireharness while under the plenum. I will do that. I haven't checked the availability or prices on these items yet. Do you know if these are availbe from parts stores or only the dealers?
However, none of the posts on this formum seem to talk much about the EGR valve. Is it possible that the EGR valve is causing the KS to show failure? Or visa-versa?
Should I change the EGR whil I am at it? The EGR is $165 from AutoZone.
Also, where can I get a FSH (field service manual?). I see posts talking about downloading one.
Many thanks!Richard
