Cause I assume you have'nt started yet on this ,I'm comin back like Columbo - ONE MORE THING!
Like that guy Scotty Kilmer emphasizes is "Use the factory brand / part # for plugs - period " .We all know a motor may have miles , or issues that may warrant , even NEED adjusting plug specs . Colder , more or less nose projection , material ie. PT , CU ,IR ,RH whatever whatever - been there done that . He also suggests to hold up the removed old plug and 'match it' to what you're now gonna put in there ! Better , know your thread depth , nose projection , need colder ?hotter? , etc. But see that plug TERMINAL at end of insulator is NOT shorter !!!!! A little longer (1-2mm??) - judge that one yourself .
So IF'n the plugs you put in are at all " short " , PLUS one or more of the little 'contact' springs , if in there, have come out - I believe the scenario would show as seen by you ??? Maybe .
Cause all mfr's can stray more or less in these dimensions , especially if changing ANY aspect of factory brand/part # . Hell even after 21 years , ya never know even 'OEM proper' part may have 'drifted' dimensions and a lost spring(s) will add a huge pre-gap before spark passes through the plug?
p.s. Waaaaay back , J.C. Whitney sold a pre-gapping , inline attachment for distr, cap center terminal . They really sold SOME SH!&#TT back in the day......... LOL
