99 I30 replace radiator
muthiahmerchant
Car: 1999 Infiniti i30
I was trying to replace my radiator. removed bunch of screws on the top but could not remove the electrical connector. Any tips on how to remove the 2 electrical connectors is greatly appreciated.
Thanks
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
On top of the connector, away from the radiator, there is a release tab. Depress/squeeze it and then pull out the plug.
Any reason why you are replacing the radiator? In our 99 I30 there was a radiator leak so I used Bar's Leak Pelletized Radiator Leak Sealer. Then I realized that there's a 4-inch crack just below the filler neck. I used JB Weld Stik to seal the leak and so far, repair looks good. Of course this is only temporary while I weigh my options - OEM radiator from IoS is @ $425 while aftermarket is @ $125. I normally go for OEM part but this time may go for OEM-compatible.
muthiahmerchant
After I drive for a while the top of the radiator and surrounding parts are spashed with coolant. The mechanic said I should replace the radiator. I got aftermarket radiator from advanceautoparts. But i will try the sealer before replacing the radiator. my car has 180000 miles. But in any case, how to disconnect the wiring harness. its just so tight.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
If coolant is splashed over the the area, it's possible that you have the same crack like mine, just below the radiator filler neck. As for the connector, as I have said, squeeze the tab on the upper part of the plug to remove it.
