pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Wed Mar 25, 2009 1:48 am
We pulled the ecm out yesterday to get the code off of it when checking the availability of a used unit and there isn't any corrosion on the connector there. The owner of the car has also been told by a few other people that it is most likely a bad ground and one place to look was in the main harness on the passenger side bulkhead. There is somebody with some experience with these cars stopping by to check some of the possible ground faults he has seen in the past and I'll mention the IAC valve as well. I have done as much as I can on the car as I am no longer a tech, I retired the tools about 4 months ago and now I'm a service advisor so my time is limited in the shop. I've been trying to oversee as much as possible on the diagnosis as I have more knowledge on nissans than any of the other techs although my knowledge amounts to very little lol. Anyhow, thanks very much for the info. When all is said and done I will post what was found and what it took to correct the problem.
