dwaynego1 »
https://forums.nicoclub.com/dwaynego1-u130330.html
Mon Mar 30, 2009 2:52 pm
Hi , i have a 98 4cyl Automatic Frontier,2 wheel drive with Trani Problems.Just Purchased, so i don't know the History.PROBLEM BEING....it drives in Park and there's no reverse.Could not tow backwards to turn it around when running, wheels would just skid as it was pulled.When truck was shut off....it would free wheel in 1st gear backwards though.Will Drive in Drive position Fine. and maybe some of the other gears.Can do some re-checking on that.I can't remember what it was doing right off hand.
~DiD do a Fluid Change~ Still does the same though.
I checked into the Linkage arm and clicked through the Gears from the underside when i pulled the Pan.*Fluid was Brown/red and may have been burnt a Little bit.
I found a 97 Frontier and that i was WONDERING if that Trani will interchange with my 98.I really like the Truck , and but as i read on through this Forum and anothers, it Pretty much sounds like these *Transmission were ~Crap~
THANK YOU ANYONE.....FOR ANY HELP
Modified by dwaynego1 at 7:46 PM 3/30/2009
