98 Frontier - Slack in upper timing chain
cali98
Car: 1998 Nissan Frontier
Does anyone have experience with timing chains on a 98 nissan frontier? I had the lower guide break causing the chain to come out of time and bend the intake valves. After repairing and putting it all back together, using the original chains, I notice some slack in the upper chain - I'm not sure if this was always there. The following picture doesn't have the top tensioner on, but even with the tensioner installed the slack is still there. Rotating the shaft allows the slack to rotate around the upper gears. Is this normal for a 98 Frontier? Thanks for your help.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
That seems excessive. Since you've gone through the trouble you have, I'd suggest a new chain too.
cali98
Thanks Desert Rat. Do you think the chain is just stretched out after 10 yrs of use?
Thanks
CPS
The tensioner is missing on that upper chain.
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
CPS wrote:The tensioner is missing on that upper chain.
He said that already.
Yes, chains can stretch over time.
Can you reinstall the tensioner and measure how much movement you have?
cali98
Thanks,
I'll do some more measurements this weekend. It's been a fun project. I'll keep you updated on my findings.
