97 Pathfinder coolant leak
dcorazal
I changed the timing belt on my 97 Pathfinder last weekend and need to remove the radiator for the service. For the last week since I completed the work I have can smell antifreeze when the vehicle is running (only when the window is rolled down). I followed the procedure for filling the radiator and bleeding the air from the system. I have checked and rechecked all hoses and connections that I had apart and the coolant level doesn’t seem to be going down. There are no leaks or puddles under the vehicle. I’m guessing there must be a very small seeping leak some place on the motor or a hose. Anybody know of any known problems like this?? Intake manifold, Head gasket maybe?Thanks
NISTECH
