VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sat Jul 02, 2022 5:25 am
Md is right, condenser airflow is a secondary factor to when and whether the system cycles. The fans can't "overcool" the condenser and cause or prevent cycling. On the other hand, evap airflow is a primary factor. The system pressure is a complex balance between the compressor, TXV, and the thermal load through the evap. But this sounds like a case of, "If it ain't broke, don't fix it." If it works well but cycles a little less than some other systems, trying to diag why will be complicated and maybe fruitless. If it starts working less well at some point, that will be a different story.
