NissanHunter »
https://forums.nicoclub.com/nissanhunter-u121673.html
Sat Mar 28, 2009 8:24 pm
I buy and sell a ton of hardybodys and 90 % of them have at least one broken timing chain guide. Nissan in all their wisdom used a nylon guide on the drivers side of the timing chain and a steel guide on the passengers side. A factory Nissan oil filter is equiped with a valve in it that prevents the oil from dumping out of the filter when shut off. That pressure is what keeps the tension on the timing chain. When an aftermarket oil filter is used, it will dump the oil out of the filter when the engine is shut off. When you start the engine back up there will be slack in the timing chain and the chain will slap the guides for about a second until the oil pressure is built back up and the slack is removed from the chain. This will eventually break the guides. That is why you hear the infamous rattle on start up in a lot of the Nissan truck with the 2.4 motors.
I would bet that if your truck has been run with an aftermarket oil filter at least one of the guides is broken. You can take the valve cover off and take a flashlight and look down and tell if the guide is broken. Usually the botton half breaks off first and then it will eventually break off the top half. If your guides are not broken, get a Nissan Filter on it immediatley and you should not need to replace the timing chain.
What will also happen is the timing chain will rub on the timing chain cover and eventually wear a hole in the water jacket and then all your coolant gets dumped into the motor and the truck overheats. Most people just assume it's a blown head gasket when in fact its the timing chain.
FYI all the newer replacement timing chains come with steel guides to help this problem but I have seen new timing chain guides get broken soon after being replaced due to the owner using the aftermarket oil filters.
