loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Sep 30, 2011 9:58 pm
Please do a 'spark test' first and as needed, replace the spark plugs. BTW, how many miles on the plugs? OEM plugs are rated up to 105K miles. Condenser seldom fails. Coils are expensive and should only be replaced if confirmed bad.
Clean the ground wires/points of the main engine harness. They are adjacent to the intake plenum. Just follow the main harness at the front and you will find two wires connected to the frame.
