qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Mon Dec 01, 2003 10:28 am
my 96 q is at the dealer to fix the drivers window which got stuck in the down position,I saw the remains of a metal cable sticking thru the door innards.the motor still hums,but dealer says they must replace both regulator and motor,the gears on motor are worn,does this sound likely,or are they trying to sell me a motor i dont need?teey also say car needs upper and lower links,they replaced both upper links 21000 miles ago,seem to be awful early to need doing redone,doesnt it? Also,i have not seen much talk here about replacing LOWER links,how would i know if they are indeed defective? they also wanted to replace tention rods,but would not just do the bushings,looks like a call to Joe is in order!What difference in ride-handling would i notice if upper and lower links were defective?also,what will replacing tension rods do to the ride or handling?can i wait a few months on these?
