96 TT Auto ECU Upgrade?
EHutton
Car: 1996 Automatic Twin Turbo Z32
I have a 96 Automatic Twin Turbo Z and I'm looking for a ECU upgrade. I'm getting new injectors, which will need a new ECU. As far as I've found, JWT only sells ECU's for 96 manuals, and they are expensive (almost $600). I was looking at an Ashspecz but I do not believe they make one for a 96. Does anyone have any suggestions? I'm not totally against the notion of using a older ECU if it wouldn't do something ridiculous to my car. Thanks for the help
I have now also gone through Nistune and that is pretty much out of the question due to me having no near access to a dyno tune.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
The older cars have VVT on the intake cam, something they deleted in 96 due to emissions. The automatic cars had slightly smaller cams, and ran a touch less boost in order to preserve the weaker automatic trans. I suspect running the 96 manual tran won't be an issue, the automatic trans is not controlled by the ecu. Wouldn't hurt to pick up a phone and call jwt.
also sent you an email.
