hal90000 »
https://forums.nicoclub.com/hal90000-u11792.html
Fri Nov 05, 2004 8:50 am
Seems like I have seen several posts about this problem, but I can't seem to find them.
I have had very intermitent starting problems with this car over the last year. I replaced the battery last spring. This seemed to have fixed the problem, but then again it got warm then too. We had a cold snap the night before last. Down to about freezing. Go out to car, attempt to start, no turn over. This is just like last winter. I charged the battery on a 2 amp charger all day, about 7 hours, car started fine. Get up this morning wont turn over. Headlight dim badly when on and attempting to crank. I saw several posts about the blue relay, but I can hear it click when the key is moved to the start position. I only drive the car two or three times a week so it doesn't get a lot of use.
I used a multimeter to check current draw. It was set on the 200m scale of the DCA function and was registering 190 or so. Is this the correct draw when the car is offf. Seems like I read it should be less than 100 but I don't know my scales well in electrical terms. Any sugestions or corrections? Thanks in advance.
