Have 96 Maxima SE, with the Factory Bose system, about two months ago I lost the ability to pick up ANY AM/FM stations on the factory Bose deck, not just poor reception, zero reception, nothing comes in at all. CD player works fine, Antenna goes up and down, Antenna is plugged in, the glass Antenna is also plugged in. I pulled the unit and tested continuity between the antenna leads to the respective antenna, everything looked good there, no shorts/breaks, I even went as far as to create an antenna out of wire and attach it to the connector, only then did I pick up a few random AM stations, but ZERO FM stations
