craigvalk »
https://forums.nicoclub.com/craigvalk-u44257.html
Fri Oct 27, 2006 5:34 am
Thanks.My logic / thought process is this.
I do not believe it jumped time. typically the car will run terribly in that event. It runs just fine, other than the fact that I now have a oil pressure issue and it's noisy.
I am going to remove the tensioner again and recheck that. I am also going to check the oil pressure sensor /switch, it's possible that it failed but it would be a heck of coincidence.
The timing chain tensioner is activated by oil pressure, so if it is really bad or if somehow it was not properly installed or damaged in the process it seems to me there could be a heck of an oil pressure impact, i.e. what if the oil is getting past the thing, maybe it isn't seated right, and so forth.
I think I can easily check and even replace the tensioner if needed as well as the switch for the oil light. If it doesn't work out then, it's time to visit the dealer, check oil pump?
About all I can think of. Will keep you posted. Probably be Sunday before I can touch it.
