mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Sun May 15, 2022 7:48 pm
Nissan Parts Deal shows the same roof rack cross bar kit for the 96-99 Pathfinder as Infiniti Parts Deal shows for the '01 QX4, so they might fit but there is no difference in style. (Nissan/Infiniti part number 73157-1W620) If the older version of the roof rack kit on those years of the Pathfinder have a lower profile (I have no idea), that might fit as well since 73157-1W620 replaced the older version number 73157-0W000.
'Might fit' is not a very solid answer, I know. There were numerous mounting hardware parts that were superseded by others so I cannot tell for certain if everything matches up. If you are picking a salvaged Pathfinder part, you will likely need the channel mounting hardware as well if it is different than what is on your QX4.
