sheadee240 »
https://forums.nicoclub.com/sheadee240-u661.html
Thu Jan 30, 2003 10:06 pm
It seems to be the general opinion that the swap from 91-92 cams into the S14 will produce 4-5 RWHP, so losing 4-5 hp is probably a good guess, although not too accurate if you are swapping only the intake cam. If the 92 cam to 95 motor swap is easy, then you could assume that there will not be too much of a problem with it actually fitting with a reverse style swap, so depending on how broke you are, maybe it's worth trying?
