i swapped the computer and have same issues, bty per ur advise.Q45tech wrote:Under those conditions I would just swap the ABS/TCS ecu as a quick check, AFTER making sure there was no visable sensor cable/harness damage. 3 diverse sensor codes is unusal.
Secondary TPS is a common failure as is the secondary throttle motor.
what does it say to do ??msogun wrote:My problem is solved. I turned the rotor and followed the instruction on page 7-18 and 7-19 in the owner's Manual. Try it. It works. No more SLIP, TCS and ABS lights.
