95 pickup v6 sputtering bad
alexdowns926
Car: 1995 nissan pickup 4x4 v6 xe
i have a 95 v6 4x4 pickup. when i first start it runs fine, if i drive it for 10 or 15 mins it runs fine but if i stop and turn it off for 5 or 10 mins then try to drive agian it sputters bad and bacfires and wont hardly pull itself. anybody have any idea???
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Once it's warmed up and you keep driving it, it's fine but is bad if you turn it off and then restart? So if you drove say 30 miles it would be fine until you went to restart it if you turned it off?
First thingj to check would be the ECU codes. It might not tell you the whole story but it would give us a clue of where to start, potentially.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
What have you checked so far?
s14280zx
Car: 95, 98 240sx, 79 280zx, 78 280z 2+2, 06 Xterra, 94 d21, 95 pathfinder
Did you fix your miss yet? I would suggest testing your o2 sensors, and check the wires that run above the transmission(rear o2 sensor wires and auto transmission wires). When I changed my pathfinder v6, 4 or 5 of them were melted in half including both o2 wires. They weren't secured properly and were laying across the transmission. Let us know how you make out. I have a similar problem with my 98 240sx ka, but I think it's my map sensor. I'm pretty sure your v6 doesn't have a map sensor. Wasn't sure if yours is manual or auto. Good Luck.
s14280zx
I don't know if you fixed your truck or not, but after changing my map sensor on my 240, I had no codes, but it still missed, had same symptoms as yours. Turned out my distributor cap and rotor contacts were corroded. I've learned that if you try cleaning the contacts, it almost never works. Best to replace cap and rotor.
