Vipertt »
https://forums.nicoclub.com/vipertt-u223322.html
Tue Jul 30, 2013 10:25 pm
i got a 95 nissan d21 pickup
The fuel pump stoped working! I checked the relay pass side fender between the firewall and battery checked the wires and all that, the truck was running then i shut it off then later tried to start it to move it and nothing.
took the fuel pump out of the tank and hooked it up the the battery and a battery charger and the pump works! Put it back in the tank and nothing!
some times with the whole pump assembely out and pluged into the harness the pump will work and then it wont!
i got a new fuel pump today and tested it with a battery and on the battery charger and it works. Hooked it up to the harnes and turned on the key and it worked! Put it back into the tank and back together and nothing dam thing wont work! i cant test fuel pressure since the pump wont work and at the plug by the tank i got 12volts on a yellow wire but no power at the white/blue strip wire??
can you put an extra relay in and bypass the problem if so were to put it and how to wire it up??
or has any one else have had this problem and know how to fix it??
thank for any and all help
Bill
