Projex240 »
https://forums.nicoclub.com/projex240-u4020.html
Tue Sep 30, 2003 9:52 am
Okay...I swapped the motor in and the only problems I had were. 1) The tps sensors did not plug up. The 96 model uses 2 plugs with 3 pins each. The 95 motor I swapped in uses only the 1 plug connector. No biggie...just swapped the throttle bodies. All fixed. 2)Next is the knock sensor plug was seized, so i had to work to get that one off to replace it. 3) This is the trcky part. I removed all of the egr crapand the hard pipes going across the top of the intake manifold to clean up the motor, and all of the sensors associated...didnt need them. However, for anyone who has looked CLOSELY at the wiring on a 96, there are 2 plugs that are mounted on the front of the intake manifold. I have NO CLUE what they are for, but i can trace the wires to somewhere on the manifold. Theres no reason to switch out the manifolds that i can see, all you have to do to fix the problem of the temp sensor is switch out the temp sensor from one manifold to the opther...very easy to do. I did cap off the hole underneath the t-body. But anway, what i was geting at is the two plugs on the 96 motor about 6 inches above the throttle body are replaced by only one plug on the 95 motor. One of the plugs from the 96 harness ( mine) plugs up onto the plug on the 95 motor. Howeve, now i have a plug with no sensor to go to. Im not too worried yet, seeing as how its probably dealing with some useless *** emissions crap. Here in S.C., we dont have emission tests. And the emissions laws arent enforced at all...people ride with straigh-piped 350's and neven get any problems. Does anyone by any chance know what exactly those 2 plugs are for?
I really need a service manual. Also,I had to removed the tps sensor to see if they could be switched out. Now Im pretty sure i have to recalibrate it. No biggie, but the FAQ says something about testing the far right prong for this and 1st and 2nd prong for that, but doesnt say which plug to test on...remember I have 2.
