95 J30 Died
CustomJ30
Car: Infiniti J30
Hello Board,
I Need Some Help, Just Recently I Had A New Alternator Put Onto My Car And Also A New Battery At The Same Time.....Today I Drove My Car For About 15-20 Mins And It Drove Fine No Probs. But After About 2 Hours I Went And Started The Car And Let It Sit For About 10 Mins. When I Put It Into Drive And Pulled Off The Lights Started Dimming And And The ABS Light Came On And The AIR BAG Light Flashed On For A While Then The Car Completely Died.....What Could The Problem Be :help
I Have A 95 J30
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
probably a defective alternator. also, check the fusable links.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Was it a factory remanufactured or a 3rd party? Assume the battery met OEM specifications and was fully charged before it was installed?
Hope it is an easy repair.
CustomJ30
Car: Infiniti J30
I Checked The Fusible Links And Everything There Seems Aight.....The Battery Was Brought From AutoZone And The Alternator Was The Previous One In The Car Just Rebuilt.....Are There Any Other Things I Should Look Into Before I Tow It To The Shop.....Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its very possible it was a shizzley rebuild... Anything short of factory reman isnt enough....
Autozone batteries are just fine... I replaced mine with one, and its worked fine for the past 6mo... It has like a 3 year warranty, cant go wrong there!!!
dareo
Car: 1993 Q45, 1989 240sx
you can always count on an alternator to fail, especially the cheaper rebuilds.
Mayhem_J30
Car: Ummm...My Car
Bummer. It's probably the alt like others have said. That bites because the J's isn't exactly easy to remove/install.
VimyJ
I've had terrible experiences with rebuilt alternators. Best to spend on a quality unit. You may pay more but the that cost begins to look miniscule when your're standing by your disabled vehicle on the side of the road watching all the other cars whiz by.
Eswift
Car: should be obvious enough
not likely at all, but it could be a voltage regulator problem...
timjf2
Car: hangin' out
i have a power steering leak in my J30. It is the high pressure hose. Are there any less expensive parts out there besides the dealer. also searching for after market products. New to this club and I'm just trying to figure whats going on. New owner of the Infiniti as well. She's a J30.:help
IvoryJ30t
if you can tackle it yourself, remove the hose and take it to a machine shop that does hydraulic systems. they can make you a custom hydraulic hose. its probably gonna be like $60-100.
look in the phone book under "hydraulic"
CustomJ30
Car: Infiniti J30
Last Night I Tried To Jump The J30 And As Soon As The Jumper Cables Came Off The Battery It Slowly Died Again.....So Im Getting It Towed To The Shop To Get A Quality Alternator Put On And Ill Report Back With The Results.....Thanks Everyone For Your Suggestions
IvoryJ30t
definately the alternator.
