Need help plsss!!I have a 95 altima. this is what happend...I used a brake parts cleaner to degrease some are on my egine bay, as wee all know, KA24DEs distributor always leaks, so I sprayed ita little and around it(now I think it was a dumb move), and so I thouhgtI messed uo my distributor, coz the car wont start, and I dnt see a sparkwhen I tried the spark test on the #1 spark plug. So I replace the distributor, cap and the rotor, I even tried a new ignition module, I followed the altima Hanes manual on how to replace the distributor,,(made sure I have it in TDC and in the compressor side//-rotor pointing at the #1 spark plug on the cap// but it still wont start. It cranks, but really short crank, it seems like its not getting enough spark!! I have a adjustable fuel regulator with gauge, and it shows I have fuel pressure! I replaced my coil, but still didnt do anything ...NEED HELP BAD PLEASE! I DONT KNOW WHAT ELSE TO DO! WHAT COULD BE THE PROBLEM!?
WHEN I TRUN THE KEY, IT ONLY CRANKS ONES, THEN MAKES THE SOUNDS OF A DOG TRYING TO CATCH ITS BREATH!HELP PLSS..THX
5SPEED/COLD AIR INTAKE/HEADERS/EXHAUST/APEXI NEO SET ON +7%BATTERY IS GOOD(11.3V SHOWS IN MY NEO)
ALSO, MY OIL PRESSURE LIGHT IN THE DASH IS ALWAYS LIT, I CHECKED THE CONNECTION, AND IT WAS BEARLY CONNECTED, SO I REPLACED IT WITH THE WIRE CONNECTOR, ITS ALL TIGHT AND I THINK CONNECTED, BUT THE OIL PRESSURE LIGHT IS STILL ON...ANY IDEA WHY? JUST HAD OIL CHANGED, SO I KNOW I HAVE OIL!
GUYS, PLS..NEED HELP..THX
Modified by pony1 at 8:34 AM 10/30/2008
