:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Oct 15, 2003 3:40 pm
I'd bet it's timing...
Have you hooked up a timing light while you try to crank it?
If not, do that...and I bet when the light flashes you don't even see a timing mark.
Move it one tooth to the left, and with the distibutor turned fully clickwise, try to start it. Then move it fully counter-clockwise and try again. Check with the timing gun - You'll be able to deduce when it's getting close...
And an engine CANNOT lose compression just by sitting around...unless we're talking about a 1953 checvy motor you just picked up from the junk yard. But not a couple-year-old KA...
And compression will suck when cold, especially if you haven't primed the oil...dry cylinders don't seal well.
Later - Brian
