95 240sx Will Not Start. seems to be a common problem
stevil_knevil
Car: 1995 Nissan 240sx
Ok, here's the deal. I have a 95 240sx. I've done research on all the not starting problems:
Fuel pump is priming.Fuel injectors good, getting to each cylinder.spark plugs good.plug wires good.timing is perfect.grounds are good.
when I test spark on the valve cover, the sparks are spaced out as if it were a v8 dizzy. that normal?
the guy I bought it from said the distributor was bad. but i've seen alot of ppls problems that they thought were the dizzy, to be a ground wire, or some wiring under the dash?
grounds are good. i even added 1, and i checked the ecu plug, and connection is fine.
i'm just trying to see if there was something i need to check out before just buying a new distributor.
any advice would be greatly appreciated. thanks!
Thamm
Car: 2001 Lexus IS300, 2003 Toyota Matrix, 1993 Honda Civic
did you check your starter?btw welcome to nico!
stevil_knevil
yeah, starter is fine. it'll crank and crank until it kills the battery. still no go.and thanks!
Brandon93240
Car: 1993 240sx
You need to check the output on the camshaft position sensor, it is built into the distributor. It sends a signal to the ecu which in turn tells the coil when to pulse(which is also built into the distributor on the s14). If you have intermitted spark issues this should be one of the first things to look at. If you need a pinout give me your email and I'll send it to you so you can further trouble shoot.
stevil_knevil
that would be a great help. my email is [email protected]
stevil_knevil
ok, so i replaced the distributor today. no different.put a lil' oil on top the pistons and sprayed it out onto the cylinder walls,cranked it over with the injectors unhooked & fuel pump fuse pulled.hooked it all back up, dropped the plugs back in, after checking for spark again, and spark is a go.still no start.....just cranks and cranks.doesn't even act like it wants to start.
i checked the wiring harness before the ecu, and is it normal for them to have half the harness spliced in different orders. like some wires splice & split into 2 or 3 wires, and some have 2, 3, or 4 wires splicing into 1 wire before it gets to the ecu. it doesn't look quite stock to me. but i'm more used to honda's when it comes to wiring.
does any of that wiring sound right to anyone? i'll take a pic and post it up later.anyone think of anything else that could be causing my piece of yard art, to not start? i'm about out of options/solutions on it.
Brandon93240
Car: 1993 240sx
Fuel, air, spark, timing, mechanical condition. It is one of these. Are you sure you installed the distributor correctly?
Brandon93240
Car: 1993 240sx
Do you have any pictures of the wiring harness? Also did it just die on the first owner one day and you bought it that way or did he make changes on the car(5speed swap) etc? Theres factory splices at the ecu, but it shouldn't look rigged.
lrb_2000
Car: '91 Nissan KA-T hatch
Wow, I'm having the same problem with my 95.. I replaced the distributor and fuel pump with no luck.. I hope you figure yours out, maybe it will help me. lol.
also, the red LED inside the ecu is always on in mine.. what about you? I believe that it means it has something to do with the Crank Angle Sensor or CPU.. ?
stevil_knevil
Yeah, the distributor is on perfect. tried uninstalling and reinstalling it a couple times to make sure it was't 180'd. tried alignment from the timing marks on the crank pulley, and by getting tdc with a long screwdriver on the piston. the original owner never changed anything. he just told me the distributor was bad. he was the 1st owner of the car, and wasn't anyone that would modify a car. the harness doesn't look rigged either, was just curious if nissan had the wiring spliced & split up like that form the factory. i was told that if the maf is messed up or dirty, that the car will not start. i have a maf off of a 93, but the plug is different. i'm thinking of cutting and splicing the correct plug onto my harness from the 93 harness. anyone ever heard of a maf causing a 240 to not start??i haven't looked at the ecu while the car was on either. i'll do that tomorrow and check.
x3whlmotion240sx
Car: s13
check your prolock?
stevil_knevil
what is that?? something for a security thing?
lrb_2000
So... I got mine started.
It was the fuel pump. I guess after I installed a new fuel pump I had the distributor off 180*. I swear it was dead on, weird.
stevil_knevil
i got new plugs for mine today. going to redo the timing tomorrow. hoping to have some action out of it.
lrb_2000
good luck.. fixing mine really made me want to work on my s13.
stevil_knevil
got it running finally. the dizzy was 180'd off. checked it a few times, but guess i needed to 1 more time. did the trick, and running. **whew...**
lrb_2000
awesome! I don't see how I had it off either.. I swear it was at TDC when installed the distributor.. oh well.
