94ser auto yo 5sp
mikebaze15
Car: 1998 nissan 200sx se
Hi guys i have a 94ser automatic and i want to do avenier swap i just got the motor and the trany from a 91ser can i use the same flywheel and clutch. how about the harness thats on the car now can i use the 94ser for the avenier swap.i would apreciate any info.
Modified by mikebaze15 at 4:46 PM 3/1/2010
Modified by mikebaze15 at 8:51 PM 3/1/2010
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You can use the SE-R transmission with any of the SR swaps to include the clutch and flywheel.
You use the wiring harness in the car for any of the SR swaps.
mikebaze15
Thank you for the info.Is there any sensor i should i wearry about.as far as the harness i can use the one onthe car just plug the avenir ecu correct. I am new to nissan.excuse my ? if i sound dum but before i do the swap i would like to get as much info as i can thank.
RED_DET
Vendor
2011 Infiniti G37x
The only plug you will not use on the harness is for the EGR. Everything else plugs right up. If you are using a JDM ecu, make sure you use the JDM sensors, such as MAF, water temp & o2. If you use a usdm ecu that has been reprogrammed you will use the usdm sensors.
The JDM motor will come with the jdm sensors already.
mikebaze15
thank you for taking the time and shearing your Knowledge. Do you happen to have any other info on the 5sp swap.
RED_DET
Vendor
2011 Infiniti G37x
You will obviously going to need the clutch pedal assembly for the 5 speed and either the 5 speed brake pedal or cut your auto in half. You will have to run clutch cable through the firewall. It can be done, just will be time consuming.
mikebaze15
thank you i think i have most of the info i need to work on it this weekeed.one question what clutch do you recomend
RED_DET
Vendor
2011 Infiniti G37x
ACT or Clutchnet. Depending on the power, depends on what type of pressure plate/disc combination. I have the Heavy Duty clutchnet pressure plate and 6 puck sprung disc which supports 320lbs, which I'm pretty close to.
mikebaze15
one more question should i replace the fuel pump.
RED_DET
Vendor
2011 Infiniti G37x
absolutely a must.
mikebaze15
I orther the 255walbro.what intercooler zise do you recommend
