94Q Atlanta driver »
https://forums.nicoclub.com/94q-atlanta-driver-u4277.html
Wed Oct 15, 2003 10:28 am
Greetings, Fellow Infiniti Drivers.I’m an infrequent poster (only second time) but regular NICO reader who appreciates all the good advice and knowledge transmitted in this forum. I’d appreciate any advice that y’all can offer about my rapidly approaching 90k mile service.
Without further ado, then, here’s the major service history of my 94Q (standard suspension with TCS) that has 89,000 miles on it (I got it third hand with 71,000 miles on it).
--at 87,856 miles, T3/Smyrna diagnosed the fuel pump is making noise and probably needs to be replaced (original fuel pump still in place); also then, I met Dennis (Q45tech), who very kindly performed a diagnosic and found a failure detected of the knock sensor. When Dennis did a new test, however, no current failure was discovered. (I forget the name of this sensor--it's under the plenum, I think...)
--at 81,958 miles, T3/Smyrna removed, cleaned, an resealed the valve covers; replaced a leaking oil pressure switch; replaced the trans mount; and installed a rear sway bar.
--at 73,585 miles, T3/Decatur replaced front and rear rotors and front and rear brake pads; replaced both tension rods and both upper links; and replaced right side rack boot.
--at 67,404 miles, Troncalli replaced the water pump.
--at 57,018, Troncalli replaced the air cleaner filter and fuel filter; flushed and replaced engine coolant; replaced all dive belts; replaced spark plugs; replaced leaking power steering hose.
--at 43,789, Troncalli replaced front pads and machined rotors; transmission flushed.
--at 42,985, Troncalli replaced rear brake pades and machined rear rotors.
--No major service between 42,985 and 24,926 (where the service records I have begin).
So, having read widely on the Infiniti online mechanic forum, I can see that there are quite a lot of major service functions that have gone undone or have been done less frequently than many of the folks who post here do them.
I’m intending to go to T3/Decatur this week or next for the 90k service, and would very much appreciate your input on how I should prioritize the services.
It seems that I should go ahead and have the fuel pump replaced; what about the fuel filter and cleaning dirt out of the fuel tank?
What about a transmission flush (I’ve printed the “Q45 transmision” article, which I assume is the procedure T3 follows.
What kind of attention should I give the radiator and cooling system?
What about new spark plugs?
And below are some other service procedures I’ve gleaned from the site. How do they fit into the prioritization?--put new GL-5 into the rear diff (prefer MOBIL1 GL-5)--flush braking system--exchange power-steering system use MOBIL1 syn ATF (yes ATF).
And finally, I don’t want to come across as a heretic, but are there any advantages to going to Troncalli over T3? (I understand that it’s ideal to ask for David the service writer and Bobby the tech.) The only reason I can conceive of for Troncalli having an advantage is that they might have a fuller range of diagnostic tools (due to automaker policy of withholding from independent shops the diagnostic codes necessary to evaluate newer engines).
I’d like to keep the car another 60k to 70k miles, but I’m somewhat reluctant to spend thousands bringing it up to peak operating order. I’m especially reluctant since I understand that the Q engine, being a sophisticated, heavily computerized, largely sealed object, defies an accurate forecast of its longevity. Put another way, I’m under the impression that a Q owner could do everything right and still have the engine crap out one day. But then, I’m not a terribly knowledgeable car person, so please feel free to correct my observations here and anywhere else in this post.
Thanks very much for any input y’all can offer. And thanks for all the good posts that have made for useful reading for me.
Glenn
