AlabamaDan wrote:That little nut screws out from the body and the entire part gets replaced. I think it's a 14mm and you just have to take your time. It's a real PITA to do the ones that connect to the firewall. I had to use a stubby wrench and turn it like 1/8 of a turn, flip the wrench, turn 1/8th of a turn, flip, turn, flip, turn, breath.
Oh and as soon as one comes off the hood will fall. Have something under there to hold the hood up.
Dude, you need a set of racheting wrenches. I think the nut is a 10mm, 12 at the most. Using a screwdriver, pry up the rubber and slide the wrench in under it. I think I may have even used a socket. Leave a nut connected on each bracket (finger tightened) until you are really ready to remove else you might get a little guillotine action going on. I pulled set last weekend.
