To bypass the Fuel Pump Control Unit.... from the trunk reach in under the rear deck and unplug the FPCU which is shown in the background of the pic below. Run a jumper from the pin shown in the pic to ground. The pump will now run on high speed only but the fuel pressure regulator at the end of the fuel rail will control the pressure. If the engine runs well the FPCU likely has a melted solder joint in the ground circuit.justjuiceit4 wrote:.......You can try running the fuel controller in high mode to see if that helps.
NICO lore says that you shouldn't bypass the controller and run the fuel pump on high speed for very long but we've never really nailed down how long "very long" is. The consequences are that you could prematurely burn up the fuel pump.my94Q45 wrote:......Any issues with running it with it bypassed last thing I want to do is fry something else.
I think you're going to find that the old oring in the top of the gas tank is swelled and you'll have a tough time getting it to fit into the oring groove.my94Q45 wrote:.......I have read enough on the post that if I do replace it then I need a new seal.....
+!.justjuiceit4 wrote:I would not trust a junkyard fuel pump. Running the bypass mode might create a "rich" condition at idle and moderate throttle, as the pressure regulator can not handle that fuel flow. Not sure why Nissan just did not install a better regulator than creating a complex three-speed controller.
Could someone repost the image, to help explain how to make the bypass? Thank you, in advance.goody90q45 wrote: ↑Thu Dec 11, 2014 6:58 pmTo bypass the Fuel Pump Control Unit.... from the trunk reach in under the rear deck and unplug the FPCU which is shown in the background of the pic below. Run a jumper from the pin shown in the pic to ground. The pump will now run on high speed only but the fuel pressure regulator at the end of the fuel rail will control the pressure. If the engine runs well the FPCU likely has a melted solder joint in the ground circuit.justjuiceit4 wrote:.......You can try running the fuel controller in high mode to see if that helps.
