maxnix wrote:Pull the plugs and look for the wet ones. Injectors best replaced as a rail unit on each side.
In hindsight it would have been best to pressure check the rail assembly before installation. If you end up removing the plenum to fix this you'll want to take that extra step before re-installation.
In the meantime...If you can pull the plugs looking for fuel and isolate it to left bank or right bank then you've narrowed it down to 4 cylinders. Maybe there will be fuel in only one or two cylinders but my experience is that the whole bank (4 cylinders) floods. If you're lucky it will be the PS and then you can replace the o-rings on #2 and #8 without pulling the plenum and see what happens. On the DS you could only get to #1. That's a 3 out of 8 chance of fixing the problem without pulling the plenum for about $15 worth of o-rings. Your call.
