For starters just clean the connection real good. disconect it and spray some electrical parts cleaner on it.tomanderson wrote:Thanks for the reply. No, it is intermittent bucking under load. Have tried nearly everything else and noticed your post with similar problem where you finally determined it was the CAS. My car threw a CAS code after the last episode. Do you think I should try replacing the connector first? How did you determine it was the CAS?
Thanks,Tom
