94 Q 45 fuel pump
Mach.9
:help I can't seem to get the fuel pump out because of the rear deck accessory tray. Can't figure out how to get that darn thing out! I may have to CUT it! What should I do!!:help
Rex
Car: None
Search may not be working as we just moved servers, but the best way to do the fuel pump R&R is to remove the upper portion of the back seat, then the entire rear shelf (including the tray) and then the pump can come out stright up threw the rear shelf.
Be careful of:rear shelf clips (9 I think)fuel drip (lots of towels/old t-shirts)pressure (remove gas cap & fuel pump fuse, turn over motor)the float (gas level indicator)
If you have the time, go back a few pages in this forum and look for fule pump, it's all here.
GOOD LUCK
Rex
Car: None
Okay, search is working, that should always be your first try :eek:
Look for step 8 by tangalora
Still good luck AND Welcome
