Timothy S »
https://forums.nicoclub.com/timothy-s-u242199.html
Wed Jun 10, 2015 6:55 am
Sounds like the engine works fine at high revolutions, but can't idle. Do you have a check engine light on? if so it would be nice to have someone read the code. Did the car idle slowly? Altimas have had a lot of mixture problems caused by bad intake manifold gaskets. Unfortunately, you need it to run so you can have the code read or check a gasket with brake cleaner.
If the car won't start, you can still do the basic checks:
Is there Fuel? are the fuel injectors clicking? can you hear the fuel pump running? Tried starting with the gas pedal depressed?
Is there spark? use a spark checker or timing light to see if the spark plugs are firing.
Is there the right amount of air? Try un plugging the Mass Airflow Sensor just downstream of the air filter box. this puts your car into "limp mode" to where it puts fuel into the engine even if the MAF sensor is not working. If you get it running you can troubleshoot why it is running rough.
