Hi All -
I am new here; I have found a few other threads similar to this one, but i haven't found the solution to my issue yet.
My 300zx NA 2+2 is having issues starting when cold; 5+ seconds to start. I have to push the gas pedal to the floor to get it to start. After a long/cold start, it struggles for 2 seconds or so, then runs great. It starts right up when warmed up. ECU codes I got were 32 and 34. The battery is new, i replaced the terminals on the battery, replaced the spark plugs, and the fuel filter.
I can hear the fuel pump before trying to start, but it sounds significantly different when cold. It seems quieter and has a different pitch. I have tried turning the key to the on position then off and back on, back off, etc. 10x times, and it did not make a difference.
I have looked for gas leaks but have not found any.
Please let me know your thoughts regarding this issue, thanks!
