93 Z32 Engine stopped while accelerating
Sushi VII
I was driving my girlfriends car coming back home and I was just moderately accelerating on a downhill and all of a sudden the engine cuts out. I had to press the brakes a bit hard to slow down since it was a red light but I was able to pull over and start the engine again and it was fine going home. The engine was at operating temperature and its an automatic. I don't know what it could be. Im used to working on my RX-7 so Im not too familiar with these engines.
diplomat 1
I'm pretty sure anyone on here is gonna start by saying clean all the connectors they are known to have green corrosion. Any other thing I would check is the crank angle sensor connector cause I had the problem at idle I started the car it ran soon as I gave it has in idle it shut off. And if u can check codes to see if u have any codes. Good luck
Sushi VII
Alright Ill check them out. I don't have a scanner to pull up any codes so Ill try this for now. Thanks
diplomat 1
You don't need a scanner to get codes.
300zx-z32-ecu-diagnostic-t249406.html
Hope that helps.
