remzon »
https://forums.nicoclub.com/remzon-u117873.html
Mon Dec 01, 2008 2:41 pm
so i have a 93 s13, bought it a year ago, didn't drive it from december last year to about september this year. ive been driving it for the past 2 months fixing one little problem after another... new alternator, new fuel filter, removed PAIR valve assembly, oil change, new battery. at one point the ground wire came off the alternator and the power wire melted right through. i managed to blow a couple alternator fuses (the big 75A ones) because i was missing the little intermediary plastic piece where you bolt the power wire to the alternator... i've since fixed that and the car runs and idles better than ever since i seafoamed the intake and gas tank last week... anyways the problem is that the car won't start unless i mash the gas pedal to the floor and crank and crank until it catches. it usually takes a couple tries. it's annoying as hell and i don't wanna keep doing it for fear of frying my starter. it used to start right up until the alternator wire got fried. i was wondering if anyone has a good starting point to troubleshoot this issue?? i was gonna start with checking the MAF and fuel filter and cleaning my throttle body real good..... any suggestions appreciated. THANKS!
