nuQ wrote:does it seem to happen when doing a gradual exceleration, in the 20 to 40mph range, then stomping on the gas, and no downshift. this sometimes happens w/ mine and this has been discussed here before. my transmission is also showing no other signs of problems and had a flush/filter change less than a year ago.jeff
It has always done that, and that never botherd me.
This is more severe, eg I will let off the gas and it will downshift to 2nd or 3rd quickly slowing the car.
Or I will not have much throttle at all and it will rev way up to 4k rpms before shifting.
Or it will shift at 1.5k rpms no matter how hard you are on the throttle.
very strange, and only occasionally, it normally shifts fine.
I think it is a connection to the TPS, MAF, or speed sensor. (I hope not the last as my understanding is that is deep in the transmission)
If I put it in 1st, and move the lever up through the gears when I want it to shift, it will work fine, even if it is acting weird in D
==>Lazn
