92 SX Coolant Leak - Mystery
dancad
So I had a coolant leak on the passenger side down near the starter and i thought I have a cracked engine block. The car had been running around town and the temp gage was normal when I head the hiss, raised the hood and saw a piss stream of coolant coming away from the block on the back side of the starter
So I was thinking the engine block may have cracked.
So this am I lifted the hood, popped the radiator cap and the rad was full ?
Started it up and got it up to temp and pressure and no leak can be found
Is there a relief on the water jacket or maybe a popped heater hose or something
I cannot figure this out
Any ideas
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
There's a few coolant hoses in that area. Iacv coolant lines,throttle body coolant lines, freeze plugs, heater hoses. Do a coolant system pressure test and you should be able to find it.
dancad
how do i do a pressure test
compactfean
daily
You have to have the tool. I think autozone will rent it for free. Pump up your cooling system to like 15psi, then look for your leak.
