92 Sentra SE-R wheel question!
Hondissan
Car: 2002 Nissan Altima 3.5 SE
Ok I know I have the 4x100 pattern but something threw me off guard the other day.
I had a set of Integra LS wheels that were professionally coated bronze with new Falken tires so I wanted to try them on. I put them on but noticed that the lugnuts didn't thread all the way but i tightened them. I then looked at my hub. The wheels weren't touching the hub surface at all. Why is this?
This is bothering me because the SE-R needs new tires really soon and I am thinking of just buying a set of new wheels to go with it so I can run a bigger/better tire instead of running the prepubescent 185s. Can someone point me in the right direction as to where I can get a good set of wheels for a decent price?
Thanks!
nametakennow
Car: '06 MINI Cooper S
First off, you have a 4X114.3 bolt pattern.
As for finding wheels, try Tirerack, but generally they're more expensive. EdgeRacing.com has a pretty good selection and will bundle them with tires too.
Hondissan
I went to Tirerack an put in 92 Sentra SE-R and it is giving me wheels with a 4x100 pattern.
Modified by Hondissan at 3:06 PM 11/11/2007
nametakennow
My apologies. I find that very odd seeing as Nissan used a 4X114.3 on the non-SE 240SXs, for instance, of the same year range (5X114.3 for the SEs) and for 2000+ Sentras. Anyway, I checked it and you're right.
I don't see why they won't sit right unless you're contacting something somewhere. I'd look around the wheel and see. The only other thing I can think of is that your lugnuts aren't deep enough.
Hondissan
One thing I am thinking is that maybe the center dust cover is preventing the wheel from fully contacting the hub assembly.
gtir007
Car: p10, gti-r
the wheel is not sitting right because the hole in the center of the rim is different , the honda rim is smaller
Hondissan
Thanks for your help guys.
loonx
hmm interesting..
